It is currently Thu Jul 31, 2025 1:42 am
 Post subject: Heel curve
PostPosted: Thu Nov 21, 2019 6:19 pm
This has always been an issue for me as I almost always leave them too beefy....
Can I see some heel curve profiles?
 Post subject: Re: Heel curve
PostPosted: Thu Nov 21, 2019 10:37 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I Just took a picture of my heel, but I just couldn't post it. Perhaps 10 years ago, but too old and ugly now.
But seriously. The first couple I built were too beefy and I ended up recharging them after they were attached. So many good plans are available to guide you. I just keep carving until it looks and feels right.
Tony Thatcher
Bozeman, Montana
These users thanked the author mountain whimsy for the post: SnowManSnow (Fri Nov 22, 2019 8:15 am)
PostPosted: Thu Nov 21, 2019 11:05 pm
Last Name: Colbert
City: Anacortes
Here’s my last one.
These users thanked the author Michaeldc for the post (total 2): Hans Mattes (Sun Nov 24, 2019 8:20 pm) • SnowManSnow (Fri Nov 22, 2019 8:15 am)
PostPosted: Fri Nov 22, 2019 5:12 am
I'm thinking you're talking about the transition from the back of the neck to the heel?
Saw a tip here recently on OLF, someone using a 2" mm forstner bit to cut out the transition so looking at a 1" radius.
As I was using a 2" robo-sander to work this area anyway I stole that ideal last couple of builds.
As long as the point of the bit has a good bit of wood (say 1/2" minimum) around it works well.
I drilled a 1/8" pilot hole right through, then use that as a guide to drill with the forstner bit from each side, leaving enough wood spare to clean up/smooth the transition.
P.S. Needs a drill press.
These users thanked the author Colin North for the post (total 2): Pmaj7 (Fri Nov 22, 2019 12:16 pm) • SnowManSnow (Fri Nov 22, 2019 8:15 am)
PostPosted: Fri Nov 22, 2019 8:37 am
I use a cheap little French Curve that I've had for probably 25 years now. I put a couple marks on it so I know where the start and stop is, draw it out and cut it. Every one of them ends up being a little bit different.
PostPosted: Fri Nov 22, 2019 10:12 am
Very elegant.
These users thanked the author Colin North for the post: jfmckenna (Fri Nov 22, 2019 12:39 pm)
PostPosted: Fri Nov 22, 2019 10:42 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
If you are using a tapered heel, a continuous arc from the bottom of the fretboard to the heel cap is key. An ogee shape here will leave the area quite bulky.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Fri Nov 22, 2019 3:59 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I use a 1 1/4" radius for the curve of the transition from the neck shaft to the heel. The narrow side faces of the heel below are 1/2" wide and the heel is 3/4" thick along the center ridge.
